Replacement pad for DT 990 Pro 250Ohm
Jul 13, 2020 at 10:01 AM Thread Starter Post #1 of 2
Apoth
Germany
I used my DT990 pro for over two years. I use them daily while gaming and currently working. I often wear them for multiple hours at a time. Thanks to corona currently over 10 hours a day.
After that long the stock pads are done. I want to replace the pads and now i stand before the problem: which pad should i get?
I read that the dt990 are very pad dependent and other then stock pads can alter the sound significantly. But i would like to get other then stock pads. I have relative protruding ears. And when i wear the headphones for long it can get unpleasant.
I dont think that slightly altered sound would be too bad because i am relative new to hifi and I'm not really using the best equip-
On Reddit the Brainwavz XL where recommended.
Anyone who can comment on the Idea of replacing the stock pads?
Jul 15, 2020 at 11:49 AM Post #2 of 2
Ok. I tried them out and i hate it. They change the sound big time. It sounds way to muddy(?) and bassy(?). I returned them on the same day i received them because the change was too extreme.
