replacement external battery case for D-777?
post-196928
Thread Starter
Post #1 of 3
zchen
I recent got a D-777 off a friend who 'upgraded' to a ej1000, unfortunetly he lost the external battery case for it. is the only to get one is to ask sony? and will there be any problems as this unit was bought in Hong kong?
thanks
post-197089
Post #2 of 3
purk
Hey,
Congratulations on you D-777!! Why do you need the external case? Is the Ni-Mh is not working any longer? Anyway, you should be able to get it through Sony. The part number is Batery Case EBP-20. Good luck on finding this! Your D-777 should totally destroy your friend's D-EJ1000 Headphone out! Click here for website. The price is around 14 dollars, so it not so bad!
Purk
Type "D-777" in "List Parts and acce...." and you will get the result.
post-197129
Post #3 of 3
zchen
hi Purk, thanks for the help.
As for why I need the external battery case, the Ni-Mh is working fine(and I bought some new 1400 mah ones), I guess I'm just being a "completist" and want all the stuff it originally came with.
