Mizicke5273
Hello,
I'm looking to replace the stock cable on my pair of HE-500. I'm looking for something that is easier to manage; the stock ones seem very stiff and some how end up in the way. They have also started to untwist a tiny bit in the braid. I would like something that looks decent and does not cost a lot. Budget would be preferably around $50; I might stretch a bit for better quality and aesthetics. Connectors need to be Single-Ended and preferably 6.3 mm plug. Initially I have looked on Ebay and Aliexpress and found some in the $80 range. But I want to see if there are any that cost less with just as good quality.
So are there any decent cables in this price range for the HE-500? And if not, what price range would I have to consider?
Edit: I forgot about Forza cables. They have the Color series that is around my price range. Another brands to look at?
