animefreeks
- Mar 7, 2012
Out of pure necessity instead of sound quality, I need a replacement cable for my Sennheiser HD 700's. As it stands right now, any movement in the cable will cause either the left channel, the right channel, or if done right, BOTH channels to be cut off. I am not after those 200+ dollar cables that "supposedly" increases sound quality, but rather a cheap one, or OEM replacement. I have not been able to locate any that are 10 feet or 3 meters in length for under $50. Any help would be appreciated.
The closest cable that I have found so far are these:
https://www.amazon.com/Replacement-Audio-upgrade-Sennheiser-Headphones/dp/B00KBBUKCG
Issue is that these are only 2m in length.
