infinitesymphony
- May 15, 2006
A fan-related question...
The stock 380-watt Antec power supply in my parents' Antec Sonata case died, so I replaced it with a Corsair CMPSU-400CX. It works well, but the rear case fan is now spinning at 100% and cannot be controlled with applications like SpeedFan.
The Antec PSU had a 3-pin, two-wire cable that connected to the PWR_FAN header on the motherboard; this new power supply does not have any 3-pin connectors. I'm assuming the old PSU was communicating the case fan speed to the motherboard. If I use a 4-pin to 3-pin adapter to connect the case fan directly to the PWR_FAN header on the motherboard, will that give me the same amount of control as before?
An example of a 4-pin to 3-pin adapter (4-pin side on the right):
My case has turned from near-silence into a white noise machine. Any help would be appreciated.
