Keithpgdrb
Sponsor: ZMF Headphones
- May 22, 2008
I am going to have to change the built in rca cable for my DUAL turntable. it is shorting out somehow and causing what sounds like ground noise. I still have to open it up, but I think the existing rca cable is soldered in. probably to 4 points
1. has anyone else done anything like this?
2. even if you havent done it, can you recommend what kind of cable I should use to replace the existing crappy RCA? I recall reading something about using a mic cable.
3. I've never had to solder any of my audio equipment. is there a specific kind of solder I should use?
I'm hoping this wont really be a big deal, but any suggestions would be very helpful. especially the cable recommendation.
