cotdt
- Aug 29, 2005
hi mr. gilmore, what is your thought about the measurements between the Dynahi and the Beta22? I've always been interested in comparing these two amps. What do you think is causing the ringing at 100kHz square wave on the Dynahi? I will try changing some of the values of the capacitors to see if it fixes things, since I think that may be the cause.
I will try the S22 power supply with the Dynahi and see what happens. With the Dynahi power supply, there is clipping at higher volumes on my speaker.
