proid
- Mar 21, 2011
I was wondering if this kit is good enough and how does it compare to tread or step?
P/s: i don't have the schematic
Well, it looks to be a more-or-less standard 317/337 bi-polar design.
What do you intend to use it for? That will drive the suitability answer more than anything.
You still didn't answer jdkJake's question...what amp are you powering?
We can't recommend something unless we know what it needs to do.
It comes with a power supply does it not?
If so, are you looking to replace it?
This is probably more than you need, but if you want a better power supply...
It come with standard wallmart power supply so i'm going to repalce it to get better sound quality.
Have you heard the amp using the power supply they ship with the project?
Thanks, i think i will go for the psu in millet minimax schematic, it's cheap, simple and seem to be very good.
P/s: Can i use 1N5408 instead ofMBR360 without degrade quality?
It looks to me that the MiniMax uses a pretty standard LM317 regulator circuit. Much the same as the STEPS or TEAD you mentioned
earlier. The MiniMax schematic I looked at just used 1N4004 diodes in the bridge...
