mikeg
- May 4, 2002
I don't know. The outside case of the Burwen is larger. The left knob of the Burwen is called "Sensitivity", while that of the Esoteric is called "Distortion Limiting". The LEDs associated with these controls also work slightly differently. The Burwen left knob is to be rotated clockwise until the brightness of the LED somewhat dims, and this adjustment is to be made during an LP segment that contains no music, or solely base music. That of the Esoteric is to be rotated clockwise during a loud music passage, and until the LED just lights. Actually, both of these left controls end up at about the same setting. As for the right control, although they are called different names (i.e., "Threshold" on the Burwen, and "Noise Rejection" on the Esoteric) they are adjusted the same way (i.e., after first setting the left control), and seem to end up at about the same setting. Significant distortion also becomes evident at about the same point of adjustment when the right controls of both units are turned to about the same clockwise setting. Besides size, another difference between these units is that the Burwen has a "Tape" selector button, while the Esoteric does not. As for performance, they seem to be essentially identical, and these two units are valuable additions to my two vinyl systems. BTW, my next tests will address the use of vinegar with my 16.5 RCM. But first, I need to establish how well velvet brushes, etc., stand up to somewhat prolonged exposure to undiluted vinegar. Hopefully vinegar can replace the gamut of magical elixers that are so ardently promoted by so many.
Originally Posted by bigshot /img/forum/go_quote.gif Do you think the Esoteric is just a Burwen in a different box? See ya Steve |
