thanks, i will try the channel balance you mentionedNah, too much latency for that to be acceptable, in my opinion. I actually ended up buying a cheap 7.1 soundcard that can output via SPDIF and I use that whenever I want 7.1 surround. I've not yet tried the Hifi cable method with ASIO support but this is my first time hearing about it and it sounds like the best way to go. I'll give it a shot sometime this week.
Honestly, your own measurements look GREAT, I don't think you need to get the left and right any tighter in tolerance. That has a relatively minor affect on the results you hear because Impulcifer is automatically compensating for that variance so you don't hear it as being "off" balance. I've had plots that measure +/-7 dB on one side and it still sounded perfectly centered.
I don't even bother using Impulcifer's room correction - not because it isn't good, but because it's so easy to fix any EQ problems after the measurement is made. I load an EQ VST into EQ-APO (I use Pro-Q 3 but any will work), then I make the necessary corrections while listening to music through the BRIR I'm correcting - and by looking at APO's charts - and then when I am happy with the EQ I burn it to a new .wav file by opening the original in Audacity and applying that same EQ correction. Its MUCH easier to do this than it is for me to go through the whole 14-stage measurement mic process and the results are just as good, in my experience.
You can easily adjust the balance issue you mention here (slightly to the right) by processing the BRIR with the --channel_balance=-0.5 or whatever number you want. That parameter adjusts the right channel, so if the right is too loud you can use a minus number to bring it back down so that the left sounds equal, therefor centering the stereo image.
Have you tried using reverb management? If not then I HIGHLY recommend it, it works amazingly well and will definitely reduce the amount of reverb you hear.
Here's an example of what it looks like:
python research\reverberation-management\reverberation_management.py --file="data/my_hrir/69th-Ananda-10K.wav" --track_order=hesuvi --reverb=800
The number at the end is the target length of the resulting reverb tail in milliseconds. 800ms is a good starting point for small rooms, in my opinion.
Honestly i would try to fix the reverb from its root before cutting the frequencies, because my room is pretty empty so it causes so much reverb (never had this much reverb in a room in my life, seems like a damn underground parking) and because of that i think is almost impossible to cut it out with post processing without losing details, i will tru to put some duvets and then eventually cutting the remaining reverb
