sander99
If I may take a guess: he probably did what boiles down to the same as what @Erik Garci did with his A8: Erik measured a 2 channel PRIR using one center speaker. He sent the left and right channel sweeps to that one speaker. When the A8 measured the left channel he muted the right in-ear microphone. When the A8 measured the right channel he muted the left in-ear microphone.Could you elaborate on what did you do exactly? What I gathered from this is that your measured a mono system and somehow that creates a sound stage. I'm sure this is not the case. How many speakers did you measure? At which positions? Did you do something extra to the output HRIR file that Impulcifer doesn't do? Do you need some kind of special DSP processing to make this work with Impulcifer created HRIR? Did you have some kind of special DSP processing for the speakers during the measurement? I'm baffled.
So what he gets at playback of a stereo source is this: the left ear "hears" the left channel of the input source being played over the center speaker, and the right ear "hears" the right channel of the input source being played over the center speaker. It figures that for the mono-component in the signal it sounds very natural, because for that mono-component the total works the same as if that mono component had been sent to a "normal" virtual center speaker. Non-mono parts of course will have ILD and/or ITD clues. The further out of center sounds are placed the further there will be a mismatch between the actual HRTF filtering (based on the position of the center) and the HRTF filtering that would correspond with the placement in the "soundstage".
Note: I never tried any of this myself, and I do realise it is higly subjective and not at all a-priori logical to apply this to recordings that are made with a different usage in mind.
