lowdown
- Jan 4, 2015
@lowdown: I have a feeling you don't understand what musicreo is saying. Normally impulcifer uses your headphone measurement to insert the headphone equalisation (or compensation) in the resulting hesuvi.wav file. So when using it with the HeSuVi software you don't use additional headphone compensation (because then you would compensate double).
When you run python impulcifer.py you can use the option --no_headphone_compensation and then no headphone compensation is inserted in the resulting hesuvi.wav, then your headphone measurements are not used at all.
You're right, I don't understand all the options or how the pieces of this sonic puzzle fit together. It's taken me a while to even figure out how to connect the HW correctly.
