I will respond to each point in your message.
It may or may not be necessary.
If the angle and insertion depth are exactly the same, it might not matter, but even then, the acoustic characteristics of both ears can differ, which means the ultra-high-frequency response might inherently vary between ears.
Now, even without a calibration curve, let’s assume the following:
For instance, let’s say the left (L) microphone has a flat response (zero), and the right (R) microphone has a response as if a negative high-shelf filter is applied.
In this case, the same characteristic will already be applied to your headphone profile and room response, for each channel and for each input microphone.
The L microphone was flat—no change.
As for the R microphone, we assumed it has a response with a negative high-shelf filter.
Let’s further assume that the room response applies a roll-off in the ultra-high frequencies, resembling a negative high-shelf filter.
In the headphone response, the same negative high-shelf filter would apply.
Since the headphone response would overcompensate by the exact amount of the negative high-shelf applied, the end result wouldn’t show a significant difference.
Therefore, you can skip the calibration step.
You don’t need to place too much importance on this.
It doesn’t matter whether you use pink noise with an RTA or a sine sweep. Measuring without applying EQ first and then applying EQ afterward will yield the same result.
In fact, I argue that the use of DRC systems like Dirac, which employ FIR filters or mixed-phase processing, is better avoided. This is a view I advocate within the Korean community I’m active in.
- Impulcifer’s impulse detection and processing are highly sensitive.
- As mentioned in point 1, we cannot know whether you wore the microphones correctly. If the response is inconsistent or if the microphone faces the wall of the ear canal, the resulting impulse will naturally differ.
- We also don’t know if your speakers are linear or if direct sound from your speakers is free of interference in your room when it starts.
For these reasons (points 1, 2, and 3), there is a chance, albeit rare, that incorrect processing could lead to distorted sound output.
Therefore, if there’s anything you need to adjust, simply apply basic EQ to the low bass range (20–200 Hz) and leave it at that.
The numerous dips and peaks within the ear reflect the way you perceive sound.
As these become smoothed out, the result drifts further away from your natural listening perception, making it less precise.
I’ve experimented not only with basic smoothing but also with techniques like FDW (Frequency-Dependent Windowing) and MTW (Multi-Time Windowing).
Ultimately, the most accurate representation was the raw, unsmoothed state.
You can apply it manually; it’s not difficult.
Using PEQ to smooth out room modes doesn’t require many filters and is straightforward.
If you know how to use REW, you can also use its AutoEQ function.
