Recommended PCI-E 1x sound card
Jul 9, 2011 at 6:21 PM Thread Starter Post #1 of 4
Jmatt110
Jul 9, 2011 at 6:56 PM Post #2 of 4
I can only speak to the Asus cards. The STX is not intended as a "gaming" sound card. It's intended purpose is to be a very high quality, customizable, consumer audiophile / headphone card. Since it looks like you are mostly a gamer, if you are willing to go PCI, then the Xonar ST (with better jitter control and some say better sound) and optional 7.1 expansion card (for games/movies) might, IMO, be a better choice for gaming-movies-music in the Asus sound card family.
Jul 9, 2011 at 7:08 PM Post #3 of 4
Taking in account the priorities you've set and the gear you're planning on using, the X-Fi Titanium HD is without a doubt your best bet. It's the best gaming card there is, with SQ on the same level of Xonar Essence ST/STX (Asus' top tier cards), and is customizable as well.
Jul 10, 2011 at 8:15 PM Post #4 of 4
I will recommend to try X-Fi Titanium HD or D2X for gaming and both overall performance is good for music and movies.
