Megane
- Dec 13, 2008
Hi guys!! I'd like to enter in the world of portable amp, to give a good boost to my beloved d2. But i'm totally newbie, so i'be very grateful if you can suggest me a good entry-level portable amp. For entry-level i intend a good, not too expensive amp (i can spend max 150$ probably just something more); Consider that i'm going to buy a good IEM, i'm not sure yet between UE triple hi fi 10pro or shure 530. What's the best possible combination in this range of price? And, above all, is it a worthy expense? Actually i use only a simple pair of creative ep630 and sennheiser cx300, with 300-350$ it'll be a huge improvement in the sq?
Thanks you all!
Thanks you all!
