slindeman
- Jun 25, 2001
ER6i tips won't work on Marshmallows. ER6i has the smaller diameter tube so its tips are compatible with Shure headphones (except E2). All of the canalphones have a larger diameter tube. You can use Shure E2 tips with most of them, but it is a tight fit usually.
I've heard a few of the lower end canalphones, including the bigger brother of Marshmallow, the FX55. These are ok alternatives to free earbuds, but none have much in the way of detail, soundstage, or a smooth frequency response. They can be fun, but I would highly suggest moving up to headphones that actually sound quite decent, such as ER6i or JBL220. ER6i has excellent isolation and great clarity and detail, but is not a "fun" headphone as such. For more fun, something like JBL220 is great, with a strong punchy bass, good detail, and a great soundstage for a canalphone.
Does it have to be an earbud/canalphone/iem? For less money you can get better sound in a standard headphone like KSC-75, PX100, or SR-60.
Originally Posted by dyzzy /img/forum/go_quote.gif I think I'll probably end up getting the Marshmallows and then mod them if I don't like how they sound at first. Also, from reading the forums, it seems like replacing the tips is a good idea. Has anyone tried using the tips from the EX71 or the foam tips from the ER6i (my friend uses the weird tip with the three things coming out so I could probably borrow his foam ones)? I don't want to also have to get an extra pair of tips if I can just use ones I already have. |
