Eudis
- Sep 6, 2014
Hello,
I've recently purchased an AKG q701 and loved it. Paired it with a Fiio e07k and loved them even more. Coming from a Superlux hd668b, the improvement was stellar except for the bass. The only issue I ran into was they leaked sound waaaay to much and they are not that portable. I then looked at the akg k545 and fell in love, partly due to its build, portability, reviews, and because people claim it sounds very similar to the q701 with more bass and better isolation.
Recently got my akg k545 and it was just plain disappointing. Sounds sounded incredibly tinny, left cup was significantly louder. Virtually no bass, much less than the q701 and significantly less than the superlux hd668b. In fact the hd668b sounds a thousand times better. The only thing the k545 had at that point was it's build quality and looks. I'm in the process of returning it and hopefully it was just a defect. As of right now I'm looking for alternatives. So for I'm liking the Beyerdynamics 770 250 OHM and the V-MODA Crossfade M-100. My price point is $250 and my musical preference is literally everything. From Electronica to classical, to rap and hiphop(praise Najubes) to country, funk, soul, literally everything, although I absolutely love classical.
Currently I own a:
AKG Q701 Lime: for home use.
Fiio e07k:Can drive up to 300 ohm
Superlux hd668b: gave them to the fiancé.
Xiaomi Pistons 2.1.
Thank you for your time!
Currently I own a:
Xiaomi Pistons 2.1.
