itsborken
- May 22, 2007
I have a set of three M&K Sound MPS 1611p active monitors and one of the amps is giving me some issues. M&K shuttered its operations a few years ago and while I can get these fixed through the company that bought their assets, I'm wondering if there is anything similar that will do just as well or better in the HT arena.
Basically the 1611ps are XLR fed to biamped 50w tweeter/100w woofer with an 80hz filter. The filter isn't that important as the Anthem SP I'm using can provide the same function and everything below 80hz goes direct to the subwoofer anyway.
If the company happen to have timber-matched active tripole surrounds, so much the better.
Thanks!
Thanks!
