Recommendation for Noise Canceling Headphones
Sep 25, 2023 at 9:13 AM Post #2 of 3
Hi.
Any good noise canceling headphones with great sound that you can recommend?
The Mark Levinson 5909 sounds excellent and ANC works well.
Sep 26, 2023 at 2:59 PM Post #3 of 3
I've had about a dozen for the business, and the Bower & Wilkins PX7 sounded the best. The Carbon edition feels durable and doesn't use leather if that's an issue. The auto on/off when you put them on is great, and the 13 minutes it takes to fast charge them is another plus. The noise cancelling is as good as anything except for the Sennheiser HD450BT which is king for isolation and NC but doesn't sound as good (it's ok just not in B&W territory, but much less expensive). The HD450BT is the only pair that cancelled out a leafblower on the other side of the door when the landscape crews comes through (that's my benchmark test).
