rotter2142
- Jan 7, 2010
I'm using a MacbookPro (Late 2009 version) with OS X 10.6.8 loaded on it.
The 3.5mm jack at the headphone-out has suddenly stopped working but the in-built speakers are still working fine.
I'm confused if I need a DAC or an external sound card?
I love the sound signature of the CK10's and my main earphones, the HJE900 and would like a system that complements them(mainly the Pana's).
My budget is 50USD(+10USD if it's absolutely important) and would love it if you can recommend me something that is cheaper than this too.
Frankly, I'm not an audiophile, but I do recognize sound improvements from better systems. Hiss is an absolute no-no...and I prefer a sound signature which is more mid-centric and with a deep and punchy bass.
PS : I'll be using the DAC/sound card back here in India, so replacement/warranty due to failure of product won't be possible, so need a product that is quite reliable.
On a side note, do you have any idea where I can find Sleek Audio replacement cables for HJE900 other than B&H? because it says it is out of stock.
