Dr. Strangelove
- Jul 21, 2007
Here are the specs I want it to meet:
-22 or 24 awg
-2 conductors per jacket
-preferably dual jacketed or bonded pair.
I want to go balanced, which means I need a cable that can carry 4 conductors total. I do not want to use quad cable (two channels of unshielded audio in the "same room" doesn't sound good imo).
Here are two of my picks:
Belden 1504A/9451d
This conductor has two shielded cables bonded together. Think of it like speaker cable. This makes it easy to work with however the cable is wider vs the standard quad cable.
Belden 8728/9402
So this is a two-in-one package: two shielded cables inside a shielded cable.
Problem being that when I cut off the jacket so I can split to L and R, the shield will be showing for the wires going to L and R. Not sure how I can fix that (Want to keep shielding to the entry points). The 9402 does not have shielding outside the pair of connectors.
Both of these cables use beldfoil shielding.
I know pretty much nada when it comes to re-cabling. I know enough about soldering to preform the task of connecting wires and connectors, but I am ignorant to everything else. What is heat-shrink? Do I need techflex? Are my cable choices even suitable for this application?
I am starting to wonder if these cables are too think for headphone use. I don't move around a lot but they might be quite heavy... should I just go with regular quad cable?
Thanks to everyone who provides input.
-22 or 24 awg
Belden 1504A/9451d
Belden 8728/9402
