hughwi
- Aug 26, 2007
Hi guys,
I have done a quick search of these forums, and could not find anything directly relevant, so here is my problem, any help would be greatly appreciated. I am using a Zepto Znote 6224W laptop, which has the Realtek HD Audio 7.1 soundcard integrated into it (rubbish i know, i have an external card on the way). It has a combined heaphone out/spdif socket, which i have been using with a standard 3.5mm jack to RCA adapter, but there was a fair amount of interference. The laptop is running windows vista 32bit and foobar ASIO.
I have now plugged in an optical cable to connect up to my Beresford DAC, but i cannot get any sound output at all. I have trawled through all the sound settings in both the realtek application and vista sound panel, but with no luck. I have set ASIO4all to utilise the Realtek SPDIF and have even tried with DirectSound with no luck. I also tried playing a DVD through VLC and selecting use SPDIF if available and an AC3 filter, but still no sound!
This started out as a temporary quick fix for the poor sound quality untill my external sound card arrived, but now it has become something i must emerge from victorious, but somehow, even after a few hours of tinkering, reinstalling drivers, software and the like, i just cannot figure out on my own.
Any help would be greatly appreciated!
Thanks
Hugh
Thanks
Hugh
