Abouna
- Jan 22, 2004
OK, so a while a back I bought a Lepai amp to pair with Dayton bookshelf speakers (the combo everyone is so fond of for the money).
I'm using this at work with my phone via headphone out.
At first it was a sweet set-up. Unfortunately some months ago a switched from a Razr to a Galaxy Note 2. That's when my problems started.
I simply cannot go past a certain volume without the signal cutting out. Once I hit that volume level it's constant intermittent cutting out and on.
I've tried the following combos:
- headphone out to headphone in on the amp
- headphone out to RCA in on the amp
- low volume on the phone high volume on amp
- high phone volume low amp volume
Same results no matter what. I can only surmise a couple things:
- something is happening between the amp and headphone jack on the phone. Is it back looping power to the phone or vise versa somehow?
- the blue ring around the volume knob on the amp dims whenever the sound cuts. No idea what this means.
This has gotten to the point where I'm not using the set-up at all since I can't get the volume I want without cutting out.
Help!
Help!
