RCA Selector Switch Recommendation
Mar 20, 2024 at 1:01 PM Post #2 of 14
Do you need to switch three sources? Or would two suffice?
Mar 20, 2024 at 1:01 PM Post #3 of 14
I use the Solupeak ST42 and it’s worked perfectly. Doesn’t seem to introduce any unwanted noise, so I assume the U31 would also be good quality
Mar 20, 2024 at 1:03 PM Post #4 of 14
Mar 21, 2024 at 12:29 AM Post #7 of 14
Mar 21, 2024 at 10:04 AM Post #9 of 14
Mar 21, 2024 at 2:18 PM Post #11 of 14
Feb 20, 2025 at 7:03 PM Post #12 of 14
I recently bought the Solupeak S1 switch off Amazon. I'm using it to route the RCA signal from my DAC to one of three headphone amps. I immediately noticed that the signal was bleeding across the channels. AKA if I had output 1 selected but had the headphone amp on output 3 turned on, you could hear the music, albeit faintly.
I aimed to isolate each tube amp and prevent feedback across the amps. I will return this one and see if I just got a defective unit, but in the end, I think I will buy something from either Pine Tree Audio or Maple Tree Audio Design.
Feb 20, 2025 at 7:05 PM Post #13 of 14
Feb 20, 2025 at 10:23 PM Post #14 of 14
I also have a Solupeak ST42 and input #3 has some fault, right channel only works if I physically press on the RCA connector. Kinda made me doubt the quality of the whole thing.
