dmbr
- Jul 17, 2014
It seems that Razer Surround Sound is preventing other surround sound programs from installing properly, even after being thoroughly uninstalled (cleaned the registry of all things "Razer").
When trying to install Daren Fong's Out of Your Head as well as Creative's MB3, both programs install without errors, but when audio is played back through the virtual device (OOYH/MB3 surround) it comes out with horrible distortion. The sound of the distortion is exactly the same with both OOYH and MB3.
Here's how I know it's Razer's fault:
I actually got OOYH working by reinstalling Razer Surround, then selecting the Razer Surround virtual device instead of my DAC as the playback device for OOYH to use! Audio comes out perfectly normal, if Razer Synapse (program that contains Surround) is closed, just as it should if my DAC were selected instead.
If I select my DAC as the playback device the distortion returns--without Razer Surround installed and the RS background service enabled there is no avoiding the distortion.
Sadly, this fix only works with OOYH. Creative MB3 does not recognize Razer Surround as a compatible device, so there is no option to select it and distortion is present no matter what.
Might you guys have any clues on how to get rid of Razer Surround and perhaps even how to get MB3 working?
