Slimm
- Jan 14, 2004
Have you ever owned or run a commercial business?
Your logic is crazy. Mass production? Do you believe if an entity makes ten amps compared to a DIY making one, they're going to spend LESS money? Maybe "per part" but they're also ordering "en masse". It's my understanding that most of the DIY makers "build to order", so they don't need to stock the parts necessarily until the order is in, depending on their operation, much less have the amps sitting on the shelf waiting to be bought. A place like Headroom not only has to have the parts in stock, but amps ready to go on their inventory, plus maintain diversification of products, not to mention their overhead, payroll, and advertising costs (their primary consumer I would assume is not solely based at Head-Fi ), that adds up. They can't wait for a PM or phone call, order the parts and then build it.
And your "only difference in parts used is the casing" is equally silly, and somewhat irresponsible. While I don't build amps, even I know that's not the case.
If you don't prefer them, fine (I agree with your assessment of their products being "voiced with the 'Senn's"), but your reasoning to slag them off and in essence "badmouthing their product" in general are rediculous.
Originally Posted by lindrone Commercial entity's amps should actually be cheaper, not more expensive than DIY amps. Mass production should reduce the cost. Perhaps not "better" built, but at least on the same level. When it comes down to it, the only difference between parts used by Headroom amps and any other DIY amps is the casing they put around it... they might have thicker plates. When compared with builders like LaRocco or Ray Samuel, they are certainly not any better. The ugly "black box" look for their amps isn't something I appreciate aesthetically either. |
