z2trillion
- Aug 12, 2004
Can anyone look over this pcb and see if it will do what I think it does?
The bottom right of the board is incomplete; it'll be used for up/down counters and stuff for an encoder. I was wondering if there are any problems with the analog section of the board, or if there were anyways for the
The dip-40 outline is for an eprom which will hold the binary values of the individual volume settings.
The datasheet for the nr-s-12v is here.
The word file is the pinout for the relay.
I was wondering if I should bias the opamps, and if there would any grounding issues by tying the signal ground to the power supply.
Any help would be appreciated. Thanks.
