Chops
$40 for the Mundorf caps
$20 for the Hovland caps
$18 for the ALPS 100k
$30 for the driver tube and output tubes
$160 for the amp
A couple more things I'm going to do is replace the power switch and headphone jack, upgrade some of the resistors, probably with some Rikens or Audio Note Tantalums, and wire the output of the Mundorfs directly to the new headphone jack.
In fact, I'm getting just the slightest bit of 60Hz hum coming through with the volume set between 12 through 4 o'clock positions. I never go over 11 o'clock, but just the fact of knowing that it's there bothers me. So tomorrow, I'm going to connect a ground wire from the a/c connector to the chassis to see if that helps.
Originally Posted by Kipper /img/forum/go_quote.gif how much were the parts so far? keep it up!! |
$160 for the amp
