quick project ember build question, wire lead
Mar 21, 2014 at 9:23 PM Thread Starter Post #1 of 4
zoolzoo
Hi!
Im building a project ember tube amp. The one part of confused about is what type of wire to use as a lead to ground out the volume knob. The kit doesnt include a wire lead.
I have some solid hook up wire, and alternatively I have some 28 gauge kanthal resistance wire. Will these work? If not what is best to use?
Thanks!
Mar 22, 2014 at 9:19 AM Post #3 of 4
Looks like the answer is on page 8 of this:
http://www.garage1217.com/MANUALS/EMBER%20MANUAL%2012-31-13.pdf
When he refers to a "wire lead" he means a spent/trimmed lead from one of the resistors (or similar through-hole part).  It's not supposed to mean a hookup wire.  Even solid hookup wire is not going to bend around the little pot threads like that.
Mar 22, 2014 at 9:31 AM Post #4 of 4
Thanks! I should have realized that.
