Eudoxa
- Aug 5, 2010
Hello Head-Fi,
I'm hoping someone can answer my questions regarding the Cowon J3 and UM Miracles, output impedance, and amps/attenuators. Please treat me well.
I've read that the J3 has an output impedance of ~2 ohms while the Miracles has an output impedance of ~16. The formula for damping is "headphone impedance/source impedance" which gives a damping factor of ~8 for this particular combo. I've read that is pretty bad and will result in distortions of all kinds when using them. Can someone explain what a good damping factor for portable headphones is and how to remedy this?
I currently have a J3 + W4 setup. I've noticed that the sound seems to change on me occasionally, but I thought it was just me "feeling for something different". Is this phenomenon accurate in describing the distortions? Given that 31(W4)/2(J3)= 15.5 damping, is this a poor combination?
How do amps and attenuators factor in to the overall equation?
Finally, why is the J3 such a revered dap when it has such a high output impedance leading to a poor damping factor with the generally low impedance portable headphones/iems?
Ultimately, I want to know whether or not getting a clip+/clipZip would be the solution to this problem, but I'd like to learn as much as I can about this issue if anyone would be so inclined to explain. I'm reading about it on this forum but its going to take some time to understand it so I'm hoping I can get some direct answers both for immediate gratification and as reference for working out something is a good idea.
Thanks in advance.
Thanks in advance.
