- Oct 26, 2008
I've searched high and low for an answer, with no luck. Any help?
I know they are basic, but I really appreciate the help.
1. If you use a multimeter (digital) what ohms setting should be used?
2. Could you cut a headphone cable (with 4 wires inside) and then probe those cables to see which makes a circuit to determine which is a ground for the left and right channels, or can that damage the drivers?
thank you so much in advance
