Meloncoly
- Feb 5, 2007
Hello!
I will hopefully be using 2x Canare F12 minis with 24AWG SPC wires (pending in case answers suggest otherwise). I want to do a 4 conductor (I think that's what it's called) design. I'm going to be Litz braiding, and this would be the first time I tried braiding. So my questions are:
1. I should have no problem with the braiding part, I have a pictorial guide thanks to Chimera Labs, but how do I keep the braid intact when I'm soldering? Do I tape it? Clip it? What's the best method of doing so? I doubt my braiding would be good / tight enough that it won't unbraid itself.
2. Should I leave it bare? Or should I cover it with heatsink/teflon? This would be a short interconnect from my iRiver Line out to a soon to be Predator. Should I use different plugs than the Canare? I'm thinking Canares look cool, and since they are bigger than other plugs, then it would make soldering easier for a beginner like me.
3. Since I personally don't like liquid electrical tape (the smell makes me feel dizzy even in a ventilated room, and I feel nausea), would it be fine to wrap the solder connections in small strips of electrical tape instead? Is there a better method of doing so? Is it even needed?
4. And finally for the interconnect questions, how much cable do I use. I'm not asking for a specific length, it's just, do I want a perfect-to-the-spot-no-room-to-move length from connector to connector, or should I aim for a it can move a little approach? I see people have connectors that looks like a perfect fit with their amp. Should I aim for that, or would it be safer to make the cable a little longer so the cable isn't feeling as much tension?
I also have a question about recabling. I know that buying the individual connectors for the HD650 are expensive to me. So I wanted to use the connectors on my HD25-1 II cable. I have a Sennheiser stock HD650 cable coming for the HD25-1 II, which I will be reterminating to a Canare F12 mini. I also will definitely have some SPC cable remaining, so I wanted to see which would sound better with my preference of music. Questions:
1. How do I go about using the HD25 connectors. They look skinnier than the HD650 ones, and it looks like it's enclosed in plastic, and I can't split it like the connectors I've seen. How would I go about replacing the cables within the connector? Would it be better to just buy HD650 connectors instead of trying to salvage these?
2. I also have some mini Starquad mic cable, with the 4 wires inside and that metal shielding. Would using SPC be better or would using the mini Starquad be better in terms of sound quality and portability? These headphones will be constantly used on the go. Durability is not a factor, since I will protect the choice as much as possible with heatsink and MAYBE teflon (since I heard they cause microphonics)
Sorry this is a bit lengthy and thanks for all the help!
