Bolardito
- May 8, 2007
UE offers 2 different cables for the UE11. The one included with the product (which looks like the Westone UM2 one) or you can also purchase a thicker one which they also use for the UE10. Do you know if there is any difference in SQ between them? I was thinking on getting the thicker one for improved SQ but want to be sure prior to spend the money.
Also are they other cables than can be used from different suppliers with better SQ? Thanks in advance for answers.
