Originally Posted by dgardner What would be nice would be to have the minimum number of gain settings that allow for a pair of RS1's and a pair of HD-650's to be happy in single ended mode *and* in balanced mode (dual amp units required).
1 if you know output voltage of source and have a VR with good spec. within 50dB range.
Originally Posted by phobus Are there recommendation for high quality switches, or are they all pretty similar?
So far, I've been thinking about Grayhill Series 71 switches. Tons to choose from. Personally, I like to find one that is readily available in small quantities with PCB mount style and 6mm shaft size.
