punosion
- Dec 26, 2001
Yeah, there's a great bunch of kids over here...extremely helpful, low on the flames and other bad stuff that can ruin a good forum. Same as FutureProducers.
The one thing I have learned over here and at FutureProducers is that, if there is a good forum dedicated to your hobbies, they can swallow quite a bit of your time
As far as being useful in this tread (Sorry for the attempted hijacking, Amanda!), one of the things I look for in DJ cans is resolution. Accurate decay is needed to match up the highs, while good lows help out in hearing the beats hitting together. Some headphones I have used (DT-770, V-600) are more "warm" and "musical," which may make them a bit sloppy in regard to getting tracks matched up tightly. More detailed, and what others may say "clinical," cans (V-6) will be less smooth and make everything stick out in its own space. This is good, because you can pick-and-choose what you want to listen to, instead of trying to extract exactly what you want to hear out of a song from all its components.
Ehh, hope this helps. Keep that wax spinnin'!
