As the subject says. I mess around with the iPod eq under Rockbox and I can't seem to make the sound change. Am I supposed to use hardware eq or regular eq? Thanks.
Yes, equalizing in RockBox definitely affects the LOD. Either the hardware or firmware eq will affect it. I change the eq when using different head/ear phones. It is recommended that you use the hardware eq as it uses less battery life.
