grzzlo
- Oct 15, 2005
So the precut is the same as eq gain? Perfect. I guess I should have spent more time at the rockbox site and I could have figured it out myself. Anyway, thanks for the info.
Ok. That's what I thought you meant in the first post, but I wasn't completely sure. What with the precut, it doesnt matter too much, but I'm still curious: the bottom graph is how the curve will look _if_ the eq works like that. But is that how the rockbox eq works? I guess you're saying that's the standard way it's done, but is that mainly for hardware eq's or it that how it is for most software eq's as well? And thank you so much for taking the time to explain this stuff.
Pretty picture, by the way.
Originally Posted by Febs Find the "Pre-cut" setting in the EQ and turn it down. |
Originally Posted by donunus check out the beautiful attachment. the top eq represents the same db added or subtracted for each frequency the middle one represents the OPs eq graph in a perfect world. In this type of curve his question would have an answer no, there shouldn't be a difference between those values except for the level causing distortion if passed a clipping point. The one at the bottom represents an eq where the two +2dbs and the two -1dbs are not so tight beside each other so with this type of eq the answer to the OPs question is yes the sound would be different with those 2 settings. The letter e is what I have represented as the edge of my octave. That is the part that makes most of the difference. As you see the 0,0,-2,-3,-3 curve is flat at 0,0 because of the edges of the equalized frequencies |
