Question about output power
post-10645375
Thread Starter
Post #1 of 6
Sam21
AMP A outputs 700 mW @ 32 ohms
AMP B outputs 700 mW @ 32 ohms per channel
which AMP outputs more power @ 32 ohms ?
post-10645506
Post #2 of 6
NA Blur
They output the same power per channel, but it could be possible that AMP A has only one channel or is mono.
It is most likely that both amps have the exact same output rating, but worded it differently.
mW is power unless you meant mV.?
post-10646098
Post #3 of 6
cel4145
grand rapids, mi
grand rapids, mi
Agreed. Headphone amps will typically be rated per channel as headphones are 2 channel listening devices. It's not until you get into speaker amps where people might be buying multichannel amps that have the sum potential power listed for all channels, or monoblocks which are one channel, that you would have to watch for that distinction.
post-10646176
Post #4 of 6
Sam21
I am trying to compare these two amps:
Lake People G109-S :
Max. output level:
> 18.8 Veff in 600 ohms = 590 mW
> 13.8 Veff in 100 ohms = 1900 mW
> 10.7 Veff in 50 ohms = 2300 mW
> 7.8 Veff in 50 ohms = 1900 mW
> 3.7 Veff in 16 ohms = 410 mW
SCHIIT  Mjolnir :
Maximum Power, 32 ohms: 8.0W RMS per channel
Maximum Power, 50 ohms: 5.0W RMS per channel
Maximum Power, 300 ohms: 850mW RMS per channel
Maximum Power, 600 ohms: 425mW RMS per channel
The question is, which one has more power at 300 ohm and 600 ohm ?
post-10646202
Post #5 of 6
cel4145
grand rapids, mi
grand rapids, mi
I'm not sure exactly how to compare those ratings directly.
However, doubling the power output from an amp to a set of speakers or headphones results in +3db increase in volume. A perceived doubling in volume by the listener requires around +10db more output. So, assuming the power output is rated the same (eg., RMS vs. peak), differences between wattage are not that significant unless you start getting into at least double the power.
post-10649630
Post #6 of 6
NA Blur
I think Apex put out a simple calculator if you do a search for "Apex Amp Calculator" it should pop up.
