balcar
- Aug 5, 2002
dougbrad81 writes:
I got custom earmolds made when I bought the Etys, but they were not made to provide a complete seal. I use them sometimes, but prefer the sound and the isolation with the rubber tips. The earmolds I had made didn't place the earspeaker as far into the ear canal as the rubber tips place them.
Since the earmolds have a hole for the Ety speaker, I've occasionally used them with my older (stiff tube) Koss Plugs. They sounded pretty good--very bright, mucho high emphasis, but lacked the detail and overall quality of the Ety sound.
Impressions for earmolds have to be made by licensed audiologists (at least that's the case here in NY state). The Etymotic website lists dealers who can make earmolds as well as sell you the Ety phones. That's probably the best way (although not necessarily the least expensive) since they know how to place the holes for the earspeakers. And, I found that they charge considerably less for the whole package than they would to make the earmolds separately.
Re comparing the sound with the foamies, I've never used them since I couldn't get them to stay put in my ears.
The Sonys with the little "bass hump" on the front are the only earbuds that stay in my ears. Most others fall out easily, including a newly purchased set of Senn MX-500s
. I've even tried the SlicSounds, but they don't go in very well, and the hurt my ears. Very frustrating situation with earbuds.
have you considered a custom earmold ... |
