Question about cable endurance and quality
Nov 16, 2020 at 4:59 PM Thread Starter Post #1 of 2
element72
I bought the ATH-D700X a few years back.
I noticed the cable is cracking everywhere. The cracks are so bad it's like a knife went through them; the wire inside is fine. When I repair them with heat shrink more keep showing up. I think it happens when the cable starts to twist a lot. But it's happening on the same day. Can I just replace the cable?
Any tips, please?
Dec 4, 2020 at 8:53 PM Post #2 of 2
Any tips, please?
Do you mean the AD700X? It looks like that cable is hard wired in. You could open it up and mod it to have a 3.5mm port, but what might be easier is to just cut the wire a few inches from the headphone and solder a 3.5mm female or something. That way you can just change out the aux cable you're using with it.
