moot11
- Sep 13, 2011
Hi Guys,
I'm planing on putting together my first turntable set up and have a few questions. I'm planning on having my setup consist of the following parts:
Micca MB42X Bookshelf Speakers
Schitt Vali
U Turn Tuntable
My question to you guys, is if I'm missing anything? I did some reading, and I believe the turntable will plug into the Vali amp and the vali amp will then plug into the speakers. Is that correct?
My other question is if anyone has additional recommendations on my set up. I have the Vali already, but I'm flexible on the turntable and the speakers.
I also have a modi, but I believe this is only used with portable devices like smartphones and laptops, right?
Thanks!
Schitt Vali
U Turn Tuntable
Thanks!
