alex_cs
- Jul 1, 2006
Ok dudes, the time has come and i have no idea where to start, and was tihnking perhaps some of you have done this already. Most of the info out there is a little confusing for someone jumping striaght into it, ive been using noisy graphics based computer for years and want to build a neat music server.
My goal is to create a PC thats sole function is for music storage:
-to store at least 1TB of data
-output bit perfect coax and optical
-be basically silent
-have jsut enough processing power and memory to decode flac/mp3 etc, run foobar/winamp properly and without skips and delays.
-wired and wireless ethernet for future
So I have some basic ideas. Prior to this, I will say I can handle HDD noise as long as its not extreme. the main things i need to be silent are the CPU and the case.
-Firstly, I thought an ESI Juli@ card for the output.
-A small 20-40gig HDD system HDD.
-A couple of Serial 7200rpm 500GB WD HDD's, or even 4 of them in mirror raid (I think thats RAID 1)
-The case can be up to fullsize tower, probably best for up to 5 HDD's.
-The mobo will need to have at least 2 PCI slots, RAID 0/1 SATA, onboard graphics, 1 IDE for CDROM.
From here I need recommendations:
- A silent PSU that is solid
- A mobo/cpu/heatsink combo that doesnt need much cooling, remember this is just for music storage/decoding.
- A case that muffles much of the internal noise.
- A quiet/silent CDROM known to be good for ripping.
- If possible, and if necessary, silent internal fans to extract heat form the case.
Any other suggestions in regard to ways this project can be done would be great. Keep the above three things to semi regular computer components, nothing insane and no water cooling at this stage.
Thanks guys, Ive been looking high and low and think some of you are probably well versed here.
