Punnisher
- Dec 4, 2007
What kind of player and cans would be best?
The headphones have to:
Have large enough cups to accommodate an mp3 player such as a shuffle or clip.
Have a one-sided cable design to make wiring easier.
Be easy enough to drive without external amplification.
The player needs to have:
At least basic controls. Play/pause skip forward and backward and on/off.
Some way to enable external charging and data transfer. Most likely wired to a USB jack mounted on the headphones.
Well what do you think?
