Problems with HiFiMAN 801
Jan 9, 2011 at 11:09 AM Thread Starter Post #1 of 3
condegun
I have a HiFiMAN-801,wiht the Game Ampli Card.I bought all my Music from HDtracks in 24-96 flac,and with 98% of Tracs I´m having
Defaults,little jumps during the playing or like minicuts.
I´m using a 32 GB SanDisk Extreme Card and Sennheiser IE 8.
The same record played in the Computer,wit a basic Audio Card Integrated in the Mother Board,without any Fault.
Having this problem this kind of Expensive Equipment is really disapopinting
Thanks for your suggestios.
Jan 12, 2011 at 2:40 PM Post #2 of 3
Did you try copying those same tracks to the on-board memory and playing them to see if you still hear skips?  I have a feeling the problem is your SD card, the HM-801 doesn't seem to like many brands other than genuine Kingston Class 4.
This thread discusses which SD card brands people have found to work.  Pay the extra money to buy from Newegg.com or another reputable seller, it seems the cheaper versions of Kingston tend to be fakes.
Jan 14, 2011 at 12:00 PM Post #3 of 3
Thanks for your help,dj nellie.
You are right in the Problem,i load Music in the inside Flash Memory and sounds perfect.After i load music in a Trascend 4GB Clas 10 and it sounds perfect.
Thanks a lot for your help.
