TheGhostWhoWalks
- Jul 21, 2005
PC: Windows 7 Home Premium 64-bit
DAC: Esoteric K-01 Asynchronous USB
I'm a PC Audio newbie and this is my first try at using an external DAC. The K-01 comes with three USB modes: normal (up to 96kHz), High Speed 1 (up to 192kHz), High Speed 2 (Asynchronous up to 192kHz). Obviously, my desire is to use it HS2 mode to take advantage of the advanced clock inside the K-01 and to bypass any and all PC interference. I installed the High Speed drivers with no problem, and started using it with Foobar 2k and Wasapi. Playback is fine most of the time, but every now and then I'll get a playback error that the device is not ready and the DAC basically disappears as a usable audio device. I can press the "mode" button on the K-01 to cycle back around to USB and it will show up again. I even got a couple of blue screen crashes. I've tried decreasing/increasing the buffering size, but that seems to have no effect. I tried using Kernel Streaming, but encountered the same problem. I tried using Wasapi Event Mode but just got noise. I tried uninstalling and reinstalling everything and updating F2K to the latest, and while that seemed to help some, I'm still encountering the problem. I even downloaded a trial version of JRiver MC and tried it with that, but on my first playback I got a blue screen crash (which happened only once with F2K).
I'm really at my wit's end trying to figure out what the problem is... is it possibly a hardware problem? Or maybe some problem between Windows 7 64 and the drivers? The drivers I installed were for Windows 7 64-bit. Should I try switching to ASIO? Would trying some kind of player with smaller buffering sizes help? I've read that some people with USB DACs have better results with sub-50ms buffering, but I don't even know of any players that have that. Any suggestions/advice would be appreciated...
