kelston
- Mar 27, 2003
I can't say anything on the subject as I didn't get a cable with a Neutrik. The two cables i've gotten do not have plugs which look the same as the picture (different 1/4" plugs and the connectors aren't grey and white).
To illustrate the changes in the 1/4" plug and the connectors, i've taken a picture of both side by side.
I apologize for the quality (or lack thereof) of these pictures, I had to hold the webcam in one hand, the connectors in the other, and still figure out how to click my mouse to take the picture.
The top one is the original connector. The bottom is the new connector. The new connector is about half a millimeter less wide. Also notice the little indents in the new connector as opposed to the old. Also, the white dot is on one side of the new connector (it should point outward when connected to your headphone) whereas the old one had the dot on both sides.
Again, the top one is the old plug. The bottom is the new. I tried to get the webcam to register the "Switchcraft" text around the new connector but it wouldn't focus well enough. You can tell where the Switchcraft is written. If you notice on the old connector, there is a coppery tinge where the "male" part of the plug meets the uh... bigger part (These are technical terms by the way). This is not an error on the part of the camera, it is in fact slightly coppery-gold in color. Whether the lack of that portion of the plug makes a difference in sound quality (the Switchcraft is all silver colored) remains to be seen.
