dokebi
- Mar 25, 2002
I made a cha47 variant and it has problems when I use 2 opamps with it. However, it works perfectly fine with only one in either socket. My first thought was that it could be faulty opamps but I ruled that out by testing. My second hypothesis is that the 12v wallwart may not be enough. I would appreciate advice from anyone. Thanks.
edit: Symptoms when both opamps are in use is distortion especially when the bass in the music hits. Sometimes it can be sporadic and only occur on the right channel especially at low volumes. Again, everything works perfectly with only 1 opamp.
