Alpha & Delta
Sponsor: Alpha & Delta
- Aug 2, 2008
The ones with white stain are the correct ones?
Yes, the ones with the white stain are the correct ones.
I've been burning them in since I started this thread so I'll report in the next days .
I tried the seal test, all good. I can hear both frequencies at the same volume
I tried the test with the m1 and the bass is louder almost hurting. So I decided to switch tips and use the M1 ones on the IE and the bass is the same no matter how good I seal them. They have the same volume but the sound is general is far less powerful (distant).
Plus, could it be a sign of faultiness that on my desktop PC with the M1 50% of the volume is enough and with IE to get the same volume sometimes 100% is not even enough? Consider that they both have the same impedance but the IE has 5-8db more of sensitivity? Should it be the opposite?
They are now at 30h of burn in and I hear no change. No way they sound as they're rated.
