Shinsengumi
- Feb 14, 2010
I have a problem with my relatively new AKG K701. I've used them for over a month.
Equipment:
Marantz CD5003 --- Cambridge DacMagic --- Little Dot MKIII --- AKG K701
Problem:
Now and then I experiences a hissing noise sound or crackling on bass notes. I feel that it is most prominent heavy bass music. Noise occurs only in the right earpiece. The noise are significantly audible if you put your ear against the outside of the earpiece. It is not a constant noise but the noise is, when it occurs, as I said, on bass notes.
The strange thing is that I can listen for hours with great sound quality for several days. Then, suddenly, the noise will appear. It always comes after I have listened for at least half an hour at a stretch.
Tried:
I've tried without DacMagic, only with the CD, just the computer, but the noise is there. When I tried another headphone, a significantly poorer (Canman HP-660), the noise is gone. On one occasion when I switched from HP-660 to K701 the noise disappeared from the K701. Loose connection? When the sound occurs, I nowadays usually try changing back and forth, eased a bit on the plug, but it doesn't work anymore.
I'll try:
Clean the connector on the headphone amplifier. Which way is the best?
What do you think? Is it wrong on the headphones? Loose connection? Dirt in the connector? Faulty headphone amplifier?
Equipment:
Problem:
Tried:
I'll try:
