MisterX
- Dec 30, 2002
Yeah... I guess it does help if I actually read a post before replying to it.
So I finally (been busy/out of town) replaced the D4 diode and now all of the points to measure resistance between check out fine now. When I try to measure quiescent current draw the power LED lights up but I only get .2mA? (range is 200mA on my meter)
I think your DMM is lying to you, because the LED alone would draw more current than that.
The only problem left is how to file down the slot in the Hammond case for the PCB to ground to. All of the nail files/metal files I've used are too thick to fit in the slot...
I have a problem with my mini3 as well. After the C2 capacitor exploded due to wrong walwart polarity I replaced it by another cap but now quiescent current is 0 mA. When I turn the amp on led2 illuminates for a brief period and then fades out. I made sure battery is fully charged. Also I have replaced U1, U2 and D4 but the problem still persists, I get 0 mA and led2 illuminates very briefly only.
You pretty much replaced everything that could probably go bad in the Mini³ power section. Does the amp still work on battery power?
Is there a possibility that your wallwart is bad? Measure its output voltage.
The voltage polarity problem should not have damaged the opamps or anything else because there are reverse protection diodes D1, D2 and D3. The most likely casualties from a reversed wallwart are C2 and U2, that's it.
There must have been another problem to begin with... Go through the initial check procedures again to see where it fails.
